Old 08-06-2009, 02:40 PM   #158 (permalink)
captainslug
Misanthropologist
captainslug's Avatar
BORK! - '89 Volvo 240 DL Wagon
90 day: 21.27 mpg (US)
{Forgot to bring camera to work so I'll insert pictures here tonight}
Originally Posted by Christ View Post
Is there any reason the sprocket wouldn't have made a decent fan to push air through the motor if you'd used a shroud?
I don't want the motor driving the fan since most of the heat is produced at lower speeds when the current draw is highest. That would result in an ineffective fan.
The blower fan as-is works quite well and only consumes 16 watts (outputs 29CFM @ 12volts 1.35amps). It was temperature controlled originally, but I shorted that feature because it wasn't working as well as I wanted.
