Old 08-07-2009, 02:03 PM   #31 (permalink)
arb
Originally Posted by bgd73 View Post
the delete does work. The power needed in tight spaces is worth the extra fuel, and i did learn there is a draw even in a straight line. A manual steering version of the same car, revealed the difference.
I didn't think you be happy with the drag of the ps unit w/o the fluid under pressure, plus the wrong gear ratio - kind of like trying to start from a light in second gear - yes, it will work but not feel very good.
You might find a manual rack & pinion for your car :-)
