Old 08-08-2009, 01:31 AM   #10 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
You, Sir, are correct. You need the mounts, transaxle, pedals, shifter and linkage, and the clutch kit/flywheel. It's about a $250 conversion from u-pull-it yards.
A 3.0/3.2 transmission will also bolt up to the block, but might not fit in the car's chassis, even though they came with optional 3.0's. I think the 2.3 is a bit longer than the 3.0, but I might be wrong. I do know that when putting the 3.0 into an Escort, you're shoe-horning everything to make it fit, and the Topaz isn't THAT much bigger under the hood, that I remember.
