Old 08-10-2009, 03:15 PM   #43 (permalink)
2003protege
EcoModding Enthusiast
Silver Bullet - '03 Mazda Protege LX
90 day: 29.51 mpg (US)
90 day: 37.06 mpg (US)
Blaze - '17 Ford Escape
Originally Posted by evolutionmovement View Post
The Audi TT in question was notorious for high speed lift-off snap oversteer due to the style-over-function design. After that incident (not the only one), the optional rear spoiler was installed on all of them by the factory.
Indeed: Clarkson on: the Audi TT - BBC Top Gear
Originally Posted by Hermie View Post
I know there's got to...give downforce while reducing drag.
basically impossible. Lift or downforce is created by air having to travel at different speeds around an object. The slower air is at a higher pressure than the faster moving air giving a net force. to alter air's speed, it must encounter added surface friction or have it's direction changed through some force imposed by the surface of the vehicle.
The more you work toward a net-zero drag/lift situation at speed, the more you will reduce drag, although I would always err on the side of downforce.
I'm planning on doing a boattail *someday* and lift is my biggest concern, currently.
