Old 08-10-2009, 04:57 PM   #45 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by Hermie View Post
OEMs won't cover ANY modification of the engine that isn't replacing OEM parts. I'm quite sure your lack of an air filter isn't covered either, so what you said is pointless.
"I'm sure you were referring to blocking the air inlets of the grille, which, in most OEM "real world" scenarios, are far too large to allow for adequate cooling."
That makes absolutely no sense. Go ahead and pull off your front facia. I'm sure you'll be running plenty cool from all that air hitting the radiator. If you said "small," it would make sense.
Unless the engineers are complete idiots, a large grille allows a large ammount of air into the engine compartment and through the radiator, thus allowing better cooling than a smaller grille. Common sense.
Its not the engineers that are ideots, look at the dodge v8 5.2 pickups out there, the grill is much larger than the radiator. It doesn't take a rocket scientist to figure out design and appearance play a bigger role than what is absolutely necessary. Also many FWD cars get most of their air from UNDER NEITH the car not from the grill.
Also I am certain Ford isn't going to cover your 91 Tempo even if you don't modify it anyway. Most of us are certainly far from the manufacturers warranty.
