Originally Posted by Matt Herring
Depends what type of tire you deleted and what type of tire you added. If you removed LRR tires and added a HRR tire you will lower mpg. If it's the same tire you will have a breaking in period for the new tires that will lower mpg.
Old tires weren't fuel savers, while the new ones are.
Also, any added weight in the car will lower FE. Your seats could be an extra 50, 75, 100+ lbs. that you are dragging around in the car now.
Is there any rough figure of how many less MPG for each lbs that are added on? I.e. 1% less MPG for 50 lbs added on?
Thanks!
