ladders
If this is just a 1-shot relocation you might skip the rack altogether.Stack the ladders,tape 'em together,cover with cardboard over the "steps".Buy a $7 plastic mixing pan from the masonry section of your local building center,cut one end off it and use what's left to create a nose fairing for the ladders.------------ Strap them to the roof with the good 3-inch cinch-down straps.------ You'll have less frontal area,air won't be able to get underneath,and you won't be stuck with the rack.
