Fiberglass supplies are often found beside the Bondo at automotive stores. I like the fabric selection from Aircraft Spruce and Specialty better, though. What's "fleece," Christ? and what fabric store carries structural fabric? A friend of mine got a great deal on a bolt of silk-screen silk that wound up in a regular fabric store. Felted fiberglass is usually called "mat." A really good boat store might have System Three SB-112 epoxy resin, which will actually seal in rust so it won't swell, and let you stick polyester and bondo on top, which are much easier for sanding.
