Old 08-15-2009, 01:59 AM   #9 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by orange4boy View Post
I'm running 18 volts because it's the simplest way to keep my voltage up. I have a 6V and a 12V in series.
12V (11.5 under load) is too low to keep voltage to the coil and fuel pump high enough for my car. Keeping 18V seems to add a bit to my MPG. I have not done any good "scientific-ish" testing so take my numbers with this in mind.
See this thread:
http://ecomodder.com/forum/showthrea...e-up-7551.html
Do you have a stepper or something to make sure that you're not putting too much voltage to your ECU and related components?
