Originally Posted by jedi_sol
or you could build a custom tray to place on top of your roof, then put the solar cells in the tray.
or you could put the smaller cells in between the ridges
I was thinking more like cutting out the upper panel of the roof, and putting a flat sheet in about 3/8" deeper, so that the cells and the plexi would match up to the original roof line, nix the ridges altogether.
I also have about 3-4 sqft of black dash panel that does nothing except collect sunlight all day... I think I could use that also, if I ended up with extra cells.
Better to tab the cells together for 14V?
