I went and double checked all my connections and made sure there were not any bridged ones. I seem to be fine in that area. Quick question for checking the K-line that would be pin 4 on the freescale chip correct? And would I just need to put one probe from the voltmeter on that and the other on the chasis gnd?
*Edit- Also one more quick question, what are the range of the acceptable values for iso? Is there a list of them somewhere, and around what line in the code is that located on? Thanks
*Edit - update: I just went outside and checked the k-line, as the arduino boots and tries to run the init sequence the voltage on that line jumps all over the place. When i unplug the power to the arduino, the voltage on that line is a steady 13v. Should that line have voltage constantly? I know that the connection is bridged with the resistor.
[url=http://ecomodder.com/forum/em-fuel-log.php?vehicleid=378]
[img=http://ecomodder.com/forum/fe-graphs/sig378a.png]
