That works for molding, but the masking tape adhesive won't support the 'glass for use, so you have to extend the patch onto sound metal or primer. If you want a convex surface, it can be built up with bondo, or you can start with strips of light cardboard taped to the approximate shape. If this is a rust repair, you have to account for possible further deterioration.
