Old 08-16-2009, 08:29 PM   #3 (permalink)
GoodOak
Pickup Fuel Meiser
Blackline - '09 Nissan Frontier King Cab SE V6
Jetta - '11 Volkswagen Jetta Sportswagen TDI
Originally Posted by winkosmosis View Post
I want to get a similar full belly pan made for my XJ. The normal material they use for skids is 3/16" steel, which is really heavy. I'm thinking 1/8" with dimple die holes for rigidity, covered underneath with HDPE, would be strong and light, allowing you to have a huge aerodynamic belly pan/skid. For all I know 1/16" could even be strong enough.
Aluminum might also work
I thought I heard something about 5mm of Al doing the trick, and that would be a LOT lighter than the steel, but once you dent it, you'd have to replace the whole panel to repair it... I would think.
Thanks for the thought on the grill cover. I don't think either would be too hard to do.
Frank
RIDE A BIKE!: "If by tomorrow, every gas guzzler on the road were replaced by Priuses, we would still have the same gridlock, accidents, deaths, injuries and the same pressures to put more asphalt, strip malls and subdivisions." --Thomas Smart: SuperCommuter
