I have an update. I've been slightly successful at getting the obduino to connect to my car. I discovered that if I have it unplugged from the obd port until the actual Iso9141 init message comes up it will usually connect about 90% of the time. I don't know if this is due to an issue with my car requiring different init timings or not.
I still have an issue though. RPM, Temperature, MPH are all displayed properly and all seem to be around the correct values, but my fuel consumption does not change. It just sits at 0 gallons per/hour which leads to no mpg being calculated. Any advice on where i should go from here?
Thanks
[url=http://ecomodder.com/forum/em-fuel-log.php?vehicleid=378]
[img=http://ecomodder.com/forum/fe-graphs/sig378a.png]
