Old 08-18-2009, 02:31 AM   #447 (permalink)
Demonhawk
My Jetta - '99 Volkswagen Jetta
90 day: 22.69 mpg (US)
For me the problem isn't rare. It does it all the time, lol.
As for turning the car off after the obduino has connected it will usually successfully reconnect after i turn the car back on. Unless of course I remove power to the obduino then it struggles to reconnect again upon booting. I'm currently using a usb boarduino which i'm powering from my laptop during testing so it has constant power.
In regards to fuel consumption, correct during a drive it does not increase the fuel consumed. When i shut off the engine it says "Trip saved 0.0 gallons wasted". I also ran through all the different settings and none of them that were related to mpg, or fuel consumption were working.
I don't quite understand why all the other readings work correct though (RPM, MPH, Temp, etc), and the fuel related ones do not.
[url=http://ecomodder.com/forum/em-fuel-log.php?vehicleid=378]
[img=http://ecomodder.com/forum/fe-graphs/sig378a.png]
