Old 08-19-2009, 04:03 PM   #5 (permalink)
ALS
My thoughts on the rear spoiler is leave it alone. It is already there and if you remove it you will have to fill the holes and repaint the rear deck $$$. It isn't going to affect your gas mileage that much. If the car didn't come with one then I would say no to adding a spoiler.
Look at filling the engine and transmission with synthetic. Also doing at least a 25% grill block will help highway mileage. Look on Mitsubishi performance web sites and forums to see if there is a cheap OD gear change available. I'd bet your Lancer has a relatively low OD gear (Performance) compared to other Mitsubishi's with the same transmission.
I don't know about Mitsu's transmissions but with some Honda's it is a pretty easy mod.
