Old 08-20-2009, 12:33 AM   #5 (permalink)
mtgeekman
01 Insight - '01 Honda Insight DX
90 day: 67.82 mpg (US)
I have found one Justy forum that had some info on the gearing and even doing a swap. Though the only guy I know of that was actually going to try and do it ended up just swapping the tranny from the 87/88 into the newer car to lower the 4th and 5th gear. as for the final drive, I haven't seen any info on doing a swap for it.
I found that I can fit 165/65r14 tires on the car and I am hoping to get a set of potenza re92s for it unless there is a better lrr tire now?
Good news is I have the car running now, needed an exhaust valve and then it had a clogged injector. Still need to replace the distributor on it to fix a CEL code but its getting there.
