Old 08-20-2009, 04:15 AM   #46 (permalink)
Xen2050
Maybe they were thinking ahead by putting in the usb port & getting ready to release the "updates" to the stable software, hope so!
I think while I was playing with it, one time it went to "sleep" and wouldn't wake up without unplugging it, so maybe it's not heat related at all. But I think that was after I turned the car key "on" to wake it up, then turned it off & took out the key completely (Toyota's send power to the OBD2 port all the time apparently)
The manual does have a section on calibrating it to your true vehicle speed, says use a GPS and adjust it until it reads the true speed you're moving, has examples for tires & gears that would be 30% off... on page 14/15 of the PDF manual online. I'd assume scangauge has a similar adjustment for similar tire/ratio changes, but I don't know.
"The adjustment does not affect the vehicle speedometer or
odometer readings, but the auto computer indicated speed
and distance only."
