Old 03-02-2008, 02:45 AM   #36 (permalink)
diesel_john
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
the diesel knock could be caused by high cylinder pressure before TDC. the actual impact generating the knock, could be the piston swinging over center from rubbing the compression side skirt to the thrust side skirt.
i have measured about 750 psi right before TDC.
