For a direct bolt-on, the 5th-gen (92-95) VX and CX transmission will give you the best gear ratios. 2nd best is the HX you originally had.
Sources for gear ratios on Civics:
http://www.clubcivic.com/board/showthread.php?t=71070
http://www.honda-tech.com/showthread.php?t=2055230
