Old 08-20-2009, 07:47 PM   #3 (permalink)
ev59rag
Thanks Matt,
In my signature, you can see my EVAlbum page that has most of the details you are looking for.
I have been collecting parts for almost a year. Assembled it in 4 days. Added small things like amp meter, relays for reverse, etc after that. Still working on the (dumb) charger I have to make it automatic. Bits and pieces here and there... but right now I can use it to do errands.
Cost was around 4k-5k including car and battery. Labor, I did all the labor and adaptor plate and coupler. Range is 16 miles on 50% DOD. I dont intend to go lower than that. Its the voltage sag I am worried about.
No highways for me since I can only do 40-45 mph on this one. Limitation on the controller/volts. 72 volt controller on 84 volts. And any slight uphill is taxing my speed and amps.
I intend to go higher voltage as soon as Paul is ready with his awesome controller.
EV59rag
Parting out my EV.
ES-31C D&D Motor
Alltrax 7245 Controller
Paul & Sabrina's Controller (never used)
