Old 08-22-2009, 12:10 AM   #19 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
It would be a shame to buy a 1000lb heavier truck with twice the engine just for the task of pulling a boat up a ramp, which it will probably do 12 times a year.
Jeez, if you need torque, couldn't you just mount a winch to the Escort, or get an old-school Subaru with low range? Oooh, ooh! Make the Escort a series hybrid, and harness the torque of an electric motor to pull the boat out of the water.
Before you buy too much truck, I would run the numbers through a simulator and see what is the wimpiest, thriftiest car that can climb a boat ramp in 1st gear with 3000lbs of extra weight.
