Old 08-22-2009, 02:57 AM   #33 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Clev -
Originally Posted by Clev View Post
Got one today at Walgreens, but I'm not feelin' it. Do I need to turn it around or something?
Get a rectangular gel-pack like the one I have, put it in a sock, and place it like mine. Don't smack into the seat when you sit down because I'm sure you can burst it (so far so good the past month).
Even if you don't use the gel-pack for driving, it's still good to have one around for bumps and bruises (aka I'm not wasting too much of your money because it's a 2-for-1). You can also make Gel-packs from a mixture of rubbing alcohol and water :
How to Make an Ice/Gel Pack | eHow.com
Measure 2 parts water and 1 part rubbing alcohol. For example: if you use 2 cups of water, you need 1 cup rubbing alcohol. For larger gel packs (such as gallon size), mix 4 cups water to 2 cups rubbing alcohol. For smaller packs (such as sandwich or snack size bags) you should mix 1 cup water to 1/2 cup rubbing alcohol.
I would use a hot water bottle for this (or maybe not, the plug might hurt my back). Ha ha, would that count as an open container?!?!?!?
CarloSW2
American Solar Energy Society
