Old 08-22-2009, 03:58 PM   #9 (permalink)
aerohead
shell
rrhatbruce,nice work! She's a beaut.With respect to "angles" you might want to check out the "aerodynamic streamlining template".You can see it being used at MetroMPG's "permanent Kammback for the Metro" thread.------- It's really more about degree of curvature which will sustain the final exit angles.Your Tacoma's bed is so short,it may not be able to support such a "steep" angle at the back as 16-degrees,and you may have separated flow,which will frustrate your mpg improvement.
