Old 08-22-2009, 11:00 PM   #7 (permalink)
Hermie
Stickers - '91 Ford Tempo GL
Send a message via AIM to Hermie Send a message via MSN to Hermie Send a message via Yahoo to Hermie
Originally Posted by winkosmosis View Post
It might actually make control worse at high speed, by reducing force on the front tires. Look how far back the wing is. And it's already pretty light in front.
It's not nearly far back enough to have a lever/fulcrum effect on the front. The MR2 is a mid-engine, rear drive car, so the back end is going to have more weight. Intertia dictates that the greater the mass, the more it resists change. Rear-heavy cars will tend to oversteer, meaning the back end will want to switch with the front when traction is lost (from slippery roads, for example). The same goes with front-engine, front wheel drive cars. They tend to understeer from the weight balance being in the front (except during high-speed corners while braking. The lighter rear plus braking will lead to rear-wheel traction loss, resulting in brake-induced oversteer, but it won't try to spin you around like a top.).
While I'm sure you have unlimited knowledge about exactly how a wing-type spoiler will hamper/degrade fuel efficiency
There's no call to be rude.
and there is still pollution that is a part of your vehicle, which comes directly from the use of your vehicle's "fuel".
Not if you've got a solar-powered charger.
