Hi,
You need to look at air getting above the pan at the axle area. My Coroplast rear pan was parachuting, and actually hurt my MPG.
Good point Neil. I had a similar problem with my pan around the same place. I found out the hard way because it came loose and started flapping around under there.
( Another thing I screwed up on was when I had my front end pan too close to the suspension pieces. . It tore my front end boots on the CV axle thingee as I turned the wheels.)
