Old 08-23-2009, 11:34 AM   #16 (permalink)
woodsmith
woodsmith's Avatar
Originally Posted by winkosmosis View Post
What kind of holes will it leave? If they're just little circles you can plug them
Most of the holes will be screw holes of about 4-5mm diameter but there will be one big one that may be 50+mm that may also be rough cut to allow an aerial to be pushed through to mount on the plastic wing side bit.
Originally Posted by robchalmers View Post
just north of warrington. where are you getting your liFe's from??
You're not far from me!
I don't know yet. I figured that the conversion will take a while so by the time I am ready new sources may spring to attention. It is likely that I will import from China either on my own or as a group purchase. A chap on the Battery Vehicle Society forum recently imported a small 24V pack for his bike as a trial to see how the import process works and to see if the goods were up to spec. So far so good.
I am currently using the Thundersky specs to determine physical size and possible cell capacity to work out range and how many cells I may be able to afford and fit in the car.
No doubt they will be cheaper and easier to get in 12 months time.
