Old 08-23-2009, 11:10 PM   #50 (permalink)
roflwaffle
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Christ, some gear driven diesels did have DFCO more or less, although it depends on the pump governor. VE pumps w/ variable-speed governors can do this, but not ones w/ a min-max-speed governor IIRC. That said, most pumps, at least in small cars from the 80s on, have a 12V solenoid/plunger to cut fuel that's only active when the ignition is set to run so even if the pump has a min-max-speed governor someone can setup a separate cut-off for this and have DFCO on demand.
