Old 08-24-2009, 06:21 PM   #18 (permalink)
aerohead
angles
Originally Posted by cfg83 View Post
aerohead -
Seems like the bed is just too short to allow the cap to "flow" down to the elevation of the gate top without separation.The photo magic really helps visualize what's going on.Thanks!
I was thinking the same thing. I rotated the picture of the Tacoma to make the bed horizontal and I *think* I see two angles :
The red "12 degrees" line I show above is based on bondo's F-150 shell :
http://ecomodder.com/forum/showthrea...d-cap-583.html
rrhatbruce -
I rotated a picture of the Tacoma that was not a perfect side view, so my visual analysis may be way off. As others have said, the workmanship is beyond reproach. During your design phase, did you contemplate a "12 degree solution" with a CRX-style vertical rear window?
CarloSW2
Oops,I put my reply up above in the wrong spot---Heavens to Mergitroids!
