OK, I added the Gcode files as well as the CAD files that I created to the FAB Files page of the wiki.
The Gcode files were posted for Mach3 controller. The tools needed are a 2.5mm drill bit, a 1/16" drill bit and a 1/8" v-point etching/milling bit. the larger holes for the buss bars and the heat-spreader are milled with the 1/8" bit.
-Adam
