Old 08-25-2009, 07:24 PM   #67 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Depending on the scrub radius, which is occasionally negative with FWD cars, toe has to be set to avoid toe-out during braking or acceleration. The more rigid you can get things, the closer you can run to zero toe at cruising. Camber matters for this, too, if you are using any.
