Old 08-25-2009, 07:26 PM   #68 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by Bicycle Bob View Post
Depending on the scrub radius, which is occasionally negative with FWD cars, toe has to be set to avoid toe-out during braking or acceleration. The more rigid you can get things, the closer you can run to zero toe at cruising. Camber matters for this, too, if you are using any.
This is the term I was describing above, I think.
