Old 08-25-2009, 08:07 PM   #23 (permalink)
Whoops
Whoop's Wheels - '89 Honda Civic Wagovan
90 day: 39.09 mpg (US)
Ball joints out of the knuckle, yes. This is going to probably sound bad, but it works great and it doesn't cause any problems I have ever encountered.
Loosen, but do not remove the nut on the joint. Take a heavy sledge hammer, swing it as hard as you can and hit the side of the ball joint solidly. It usually takes 2-3 really heavy hits and then it decompresses just enough to let if fall loose.
Keep your personal knuckles out of the way.
The Following 2 Users Say Thank You to Whoops For This Useful Post:
Nden (02-05-2011), SVOboy (08-25-2009)
