Old 08-26-2009, 07:33 PM   #23 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
For casual use, even drywall is rated for vacuum forming temperatures. A bit of metal shielding around the heaters should be all you need. Old stove elements make good heaters - running at 120 V they don't glow. The most important thing is to put a fan inside the oven, with the motor outside, to get even heating. Another neat trick is to use a length of I-beam drapery track extending out the door of a narrow, tall oven. You can use cheap paper clamps and drapery rollers to suspend a sheet or a frame, and then slide it out into position for drawing. The clamp can be hinged from the bottom of the mold.
