Old 08-27-2009, 02:05 AM   #50 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Oh, there's room for a race pedal, but you'd have to get an auto pedal assembly and then drill the firewall for the mount plate for the race pedal.
If you wanted, you could also hack up the pedal assembly from a Hydro car and mount it up that way. You'd still have to drill a hole or 8 to mount the master cylinder, though.
I've got a spare pedal assembly from my '89 Civic, and there's still a set in the CRX, if you need one to play with when/if you come to get that axle, you can have a set.
EDIT: Larry's Take on the HaSport cable/hydro conversion kit It's about 2/3 of the way down the page, you'll see the image after the dyno sheets and such.
