I can't imagine how you get the electrons from it. Do you simply put two cables anywhere on the surface ?
A common solar cell is a small surface and any point is close to a cable. Does a car roof can be considered a big single solar cell ?
How does an irregular surface can work ? What if the surface is concave and/or convex ?
At least with current solar cells, each one has a voltage and an amperage so you can build a panel able to charge a battery. How do you calculate the potential voltage and amperage of any surface ?
Also, what happens when 2 surfaces are put in contact ?
And...
Of course such a technology could be very interesting, but currently I can't imagine how technically it can be used.
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving: - 5725.5 kg CO2 (5342.6+382.9)
- Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
