Old 08-30-2009, 10:58 PM   #15 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by SVOboy View Post
Yessir!
Does it use pulse width of the injector and keeps a sum?
Then keeps track of the VSS.
Then calculates fuel flow and distance traveled?
Do you need your injectors flow tested at (x) psi and (x) pulse width.
So then you will have a true amount of fuel that was measured?
The reason I'm asking is because I have all my injectors flow tested for racing reasons. Whats strange is almost 90 % of the injectors don't flow what they are rated at. For example the last set of injectors That I had flowed were 450cc/min injectors that flowed 520cc/min
Heres the pic of them being flow tested.
Or does this instrument use a fuel flow meter?
Pressure Gradient Force
The Positive Side of the Number Line
