there was a thread not too long ago, someone wanted to couple a motor to the front driveshaft of the 4WD transfer case. It would work just fine. Many enthusiasts have driven home as FWD trucks, so the strength and drive-ability is there. Your truck is 4WD, so that would work, but you'd be limited to 2WD from then on, not something I could give up. But you're from So-Cal? Do you use the 4WD for offroading?
