Yes. I'm planning to use the dash and engine harness already, but there's something called the floor harness and the engine bay harness that hook into both of those, and it's the engine bay harness that has all the annoying junk like lights and fuse box.
I might just check to see if the plugs are the same for the lights. If so, I'll go for the insight junk. If not, CRX
More troublesome than I expected. Only the IMA wiring is truly separate
