I got a question - or two
Since tire design appears to be a trade between traction, wear and rolling resistance
why is the customer only given two of the critical components to chose tires?
Would Bridgestone have any plans to list rolling resistance?
I personally could find myself loyal to a manufacture that supplied all the data, instead of having to dig thru incomplete third party data & trying to guess what tire is lower RR.
Also
Does Bridgestone have plans for any higher pressures passenger tires?
once again I would be interested in becoming a customer of such a company.
Besides a look around your local store parking lot will show many tires designed to be in the 32-35 psi range - are living a life of dangerous under-inflation.
there is not much room when you are in the low thirties before you are building up heat in a tire and getting a blow out, or wallowing the bead off the rim. I seems like the tire makers would be pushing another 5 or 10 more psi for for safety - as well as being eco-friendly & saving gas.
best wishes on the interview
edit:
crap!
well I guess this is tomorrow
So how did the interview go?
Concrete
Start where you are - Use what you have - Do what you can.
Reason: space time malfunction
