Old 09-04-2009, 12:03 PM   #1 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
lower rpm won't run lean:(
I have been doing some testing and found out that with my setup anything below 2000rpm with a lean burn of 16:1 or greater and light load my engine starts to miss fire?
I think this has to do with my injectors size 780cc/min and or my low compression 7.4:1
I'm stuck with this because I need the injectors to be the size they are for racing reasons.
I'm glad I did this test because I was going to add a taller 5th gear.
Anyway I thought I would share.
Pressure Gradient Force
The Positive Side of the Number Line
