Thread: How do I score?
Old 09-04-2009, 11:23 PM   #4 (permalink)
RandomFact314
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 31.12 mpg (US)
Originally Posted by McTimson View Post
1. I don't know. A block heater would probably do more good, but since you're in SC, it might not make too much of a difference......Also, what does your typical route look like? Unless you're driving highway miles, 40MPG is going to be very tough with an automatic. If you're getting 32 city, then that is very impressive, and you really should be happy with it.
Hey thanks!
I'm sorry but what exactly is a block heater, I understand it heats the block of the engine but is it something i bolt to the block or almost just like a normal heater that i just plug in and put under the engine to heat it up a little before i drive?
Jeez, that would be awesome if I can go up on the heat on the thermostat b/c it never gets over half anyways, even in the worst conditions iv only gone up like 1 mm haha..
My typical route I would say is litterally probably 1/2 suburbs 1/2 highway
I usually try to go 40 in the suburban roads and 55 on highway, unless its night, which case I usually go 50-55...
