Old 09-05-2009, 12:37 AM   #12 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
A dam can raise the water level close to your turbine, and provide a cushion for dry spells. However, it is nothing magic. If you figure out where an ideal dam would back the water up to, and just run a large-bore pipe from that elevation, you gain the same head-height, minus any dynamic loss from friction in the pipe. There are many on-line calculators for pressure loss in pipes.
