Originally Posted by MetroMPG
The trouble as I see it is there may not be any attached flow on the top of the roof because of the flat, vertical windshield blasting the air into turbulence upwards & to the sides. If that's the case, then a rear taper may not help much.
I'm not certain, though. I bet Phil could chime in with some sage advice. I'd say it's worth starting a new thread in the aero forum (plus that's the only forum Phil reads). I'm betting you guys won't be the last Jeepers to mull over this idea.
There isn't. It does look cool in the rain though. The windshield really needs to be bypassed
