Old 09-07-2009, 09:01 PM   #21 (permalink)
vpoppv
The $500 Electric Car
vpoppv's Avatar
Originally Posted by swede View Post
Coupler is a 7/8" bore "x" hub (the kind used for weld on sprockets and pulleys) with the clutch hub welded to it. I centered them together using a lathe, and tack welded it in place before checking alignement and final welding.
Ok, if I understand you correctly: the coupler is welded to the motor shaft? I'm guessing it's more likely you have a keyway and setscrews. Sorry to be so picky, but my setup is using a hub as well, but without any welds, just setscrews, and I don't think it will stand the test of time. Since your system has given you a proven 62 kilometers, I'd like to emulate it as best I can...
