Thread
Project IRX: CRX-Insight Renaissance Experiment
09-08-2009, 04:49 AM
276
permalink
SVOboy
Dartmouth
2010
Vegan Powa!
- '91 Honda CRX DX
90 day:
66.52
mpg (US)
Some updates on wiring: Not sure how much more I will end up hacking out of the car. The ignition will probably be the hardest to get going, but I've been prepping the insight harness and the CRX wiring. Tomorrow I will start the actual integration by chopping the insight engine compartment harness into the CRX. With all the ABS wiring removed, it's basically like the CRX stuff, but it'll be easier to use that with the other insight wire harnesses so I will chop the tucked CRX wiring and solder it up to the Insight set up with the plugs removed. As you can see in the last pictures, I've already labeled all the plugs on the insight harness so I can just chop and solder.
Picture time!
Edit: Yes, one of the pictures is an overexposed cat in a box.
EcoModder's best:
Donate to EM
Window clings
EM Shirts
Better Gas Mileage
MPG Tracking
More fun sites:
Green Home Improvement
crxMPG
Benjamin FT Jones
Vegan Recipes
Car-free Living
SVOboy
View Public Profile
Send a private message to SVOboy
Find More Posts by SVOboy
