Old 09-10-2009, 01:45 AM   #129 (permalink)
sprale
Originally Posted by theycallmeebryan View Post
Nice bike!!!! Good to see a fellow ninja 250 rider on here.
You have pretty much the same bike setup as me, I'm just a little lower on gearing. What shield do you have? One of mikes shields?
Have you messed with the jetting at all?
Custom Lexan windscreen. Dremel cut, lower vent to reduce buffeting (really helps, think ST1200/Concours). I made a template on clear Mylar using the stock mounting points, including the mirror mounts. I don't use the two upper stock mounts, it helps keep the screen more upright. More at the link.
Jets are stock.
