Originally Posted by SVOboy
Don't worry about it, you've helped enough
Did you find one?
If you have a spare DX harness laying around, the distributor normally has a 4 or 6 pin plug on it that you can use, as well. You'd have to get the other end from an old DX distributor, if you still have stuff from before the MPFI install.
