That is a good point that I hadn't thought about. Considering the only vehicle in my driveway with working AC is the Celeb. I might be able to remove the condensor from the 6k wagon and block off both grilles. Also might be able to remove the condensor from the van and increase cooling when towing. I use a fan over the trans cooler than runs full time with the fuel pump.
Winter daily driver, parked most days right now
Summer daily driver
