dirt, mud, DUST mostly, bugs. I washed it out real good
The condensor hid all that, so i was running the cooling system to the MAX, my fans might have been running all the time!!! I couldn't tell because the A/C clutch was making so much noise(cuz it turned into a lathe). I want to put some large screen in front of the radiator to catch rocks and bugs. that condenser took a beating from gravel!!!
Hoping to get some more grille blocked now...
the car is MUCH easier to drive now, i found myself doing about 55 where i normally do 50 because of the power gain/less effort required on pedal. THAT PULLEY WAS DRAGGING!!!!! Maybe I'm already getting 40....
